Hello,
I have a tag change script that is occasionally missing triggers. I watched it miss three in a row earlier today but I didn’t see anything differently happening on the PLC. There doesn’t seem to be any kind of pattern to the misses.
This is on a system running Ignition 7.6.7 with Java 7u71. The script is currently set to watch 25 tags (but will probably be watching closer to 75 once everything’s online). The OPC server is Pro Server Ex by Pro-face using OPC-DA. The scan cycle for the OPC tag in the Pro-Face software is 500ms.
The script is watching a “CycleComplete” bit in the PLC that turns on for one second (using a timer) and then off. The Ignition tag is on a scan class of 250ms. It seems like one second should be long enough to trigger though.
Does anyone have suggestions on what I could try to resolve this?
