Hello,
We have tags (UDTs and instances) that exist on an edge gateway, we are exposing the tag provider to our main gateway via Sync Services. Question is, I am almost certain those tag change events will not work on the edge node but will they execute on the main gateway that is accessing them via remote tag provider? I want to say the answer is no, but I wanted to check. If the answer is no, any ideas on a solution for this? Gateway scripts are not an option…
Thanks,
Frank
