Hello!
Ignition 8.3.2. When I’m in the Designer UDT Definition Editor editing a UDT I try and copy tags from one sub-folder and paste to another. The tags are created but lose all configuration and appear as newly created tags. The tag name is the only thing retained from the copy/paste. See below for example. The pasted tags should have tag history enabled but do not. None of the other properties are copied either. This used to work in 8.1.
