I am trying to write the blank values to the Tag depending on the type of Tag. For example, ’ ’ if String, 0 if Int, etc…
I am using browseTags to get the tag datatype as below -
Here, the question is how do I compare the datatype of the Tag in If condition as tag.dataType == 'String':
does not work.
Thanks !
try
str(tag.dataType)
That said, browse tags is considered deprecated in v8. Consider using system.tag.browse.
Also, a use of dictionaries and lists can help keep things orderly.
typeDict = {
'Boolean': False,
'String':''
tagSkipList = [
'compound',
'compound_id',
'debug',
'format'
tagPath = '[LabTesting]MV-Lillebonne1/Specs'
tagBrowse = system.tag.browse(tagPath)
tagOutputList = []
values = []
for tag in tagBrowse.getResults():
if tag['name'] not in tagSkipList:
# Add full path to tha tag list
tagOutputList.append(str(tag['fullPath']))
if str(tag['dataType']) in typeDict.keys():
values.append(typeDict[str(tag['dataType'])])
else:
values.append(0)
print tagOutputList
print values
system.tag.writeBlocking(tagOutputList, values)
system.tag.browseTags was the way to get information on tags in Ignition 7.9 and below. In Ignition 8.0+, system.tag.browse is a better option. That in combination with system.tag.getConfiguration will get you what you need
tagPath = '[default]MyFolder'
tags = system.tag.browse(tagPath).getResults()
for tag in tags:
dataType = system.tag.getConfiguration(tag['fullPath'])[0]['dataType']
Wow this is great ! Wonder how long does it takes to adopt this mindset where you can automatically convert any piece of code into the most effective and easily readable language.
I wish I could take full credit. I’m somewhat of a visual learner, so as I see other’s examples where it makes sense for readability, I’ll try to adopt it. The rest is long hours of tinkering.
I am using Ignition 8.0.13
I am trying to get the DATATYPE of a memory tag that is an Integer
using scripting.
So I searched this forum and found this post.
So I tried to just use the script console
using the script from JordanCClark
However when I execute the script I get an error:
KeyError: ‘dataType’
on the line of script: if str(tag[‘dataType’]) in typeDict.keys():
I tried to print type(tags)
and it listed a bunch of properties of the tag, but not ‘dataType’.
Nothing that it listed showed anythning like INTEGER.
thanks
Please show us the result of: print tags
Actually, I think I know what happened. One moment while I get properly attired.
You did the browse on a single tag. This won’t work because browse() will get all the children, but the dataType is on the top level.
This should return the browse of a single tag:
def browseSingle(tagName):
# Get the parent path of the tag
tagPath = tagName[:tagName.rfind('/')]
# Browse the parent path
# Return the browse result of the tag.
# If it doesn't exist, return -1
for tag in system.tag.browse(tagPath).getResults():
if str(tag['fullPath']) == tagName:
return tag
return -1
tagName = '[default]Test/IntMemoryTag'
tag = browseSingle(tagName)
if tag != -1:
print tag['fullPath'], '--', tag['dataType']
