Tag Editor - what Indicator represents
Can anyone tell me, In Tag editor what this indicator means, and I am able to toggle that.
That it's being overwritten from the default. Grey, means default, green overwritten.
If you use a UDT, make an instance and then override a part of the UDT this will indicate what has changed. Or press this to change something, like alarms
Got it,
and toggling can delete the changes made.
Yes, if you want to go back to the default, press it again.
Careful if you spend a long time overriding alarms and then accidentally press this :smiling_face_with_tear:
