Tag errors
I’m having this issue again now. Started right after modifying a UDT that already had several tags associated with it. Restarting the gateway several times did not work for me.
How did you modify the UDT?
What is the error?
More information is always better than too little…
i deleted a couple of the tags inside that is didn’t think were being used anywhere in the project. I also took a backup, not sure where to send it, but the last time this happened, it was suggested…
INFO [main-Designer-Startup] Downloading… [+0]
INFO [main-Designer-Startup] Cleanup… [+1485]
INFO [main-Designer-Startup] Initializing UI… [+1486]
INFO [DatasourceTagManager-Designer-Startup] Starting up polling tag manager, polling rate: 750ms
INFO [main-Designer-Startup] Starting module: Vision [+5738]
INFO [DatasourceTagManager-SQLTags-TreeLoader-thread-1] Starting SQLTags polling.
ERROR [TagProviderNode-SQLTags-TreeLoader-thread-1] Error loading tags underneath
java.lang.RuntimeException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing gateway function.
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager.browse(DatasourceTagManager.java:491)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager.browse(DatasourceTagManager.java:473)
at com.inductiveautomation.ignition.client.sqltags.impl.ClientTagManagerImpl.browse(ClientTagManagerImpl.java:265)
at com.inductiveautomation.ignition.designer.sqltags.tree.TagProviderNode.loadTagChildren(TagProviderNode.java:75)
at com.inductiveautomation.ignition.designer.sqltags.tree.TagProviderNode.loadChildren(TagProviderNode.java:63)
at com.inductiveautomation.ignition.designer.sqltags.tree.AbstractTagPathTreeNode$Loader.run(AbstractTagPathTreeNode.java:79)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing gateway function.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:312)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:286)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:243)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:783)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager.browse(DatasourceTagManager.java:488)
… 11 more
Caused by: java.lang.NullPointerException
at com.inductiveautomation.ignition.gateway.sqltags.providers.AbstractStoreBasedTagProvider.wrapTagsToDef(AbstractStoreBasedTagProvider.java:1187)
at com.inductiveautomation.ignition.gateway.sqltags.providers.AbstractStoreBasedTagProvider.browse(AbstractStoreBasedTagProvider.java:1142)
at com.inductiveautomation.ignition.gateway.sqltags.providers.RedundantProviderWrapper.browse(RedundantProviderWrapper.java:123)
at com.inductiveautomation.ignition.gateway.sqltags.SQLTagsManagerImpl.browse(SQLTagsManagerImpl.java:405)
at com.inductiveautomation.ignition.gateway.project.ProjectSettingsCache$ProjectDefaultTagManagerFacade.browse(ProjectSettingsCache.java:495)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.SQLTags.browse(SQLTags.java:124)
at sun.reflect.GeneratedMethodAccessor48.invoke(null)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(null)
at java.lang.reflect.Method.invoke(null)
at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:176)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:398)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(null)
INFO [main-Designer-Startup] Starting module: SQL Bridge [+55669]
INFO [main-Designer-Startup] Starting module: Mobile [+56952]
INFO [main-Designer-Startup] Starting module: Reporting [+56955]
INFO [ReportingDesignerHook-Designer-Startup] Starting up Reporting Module. Mode: Activated
Initializing ReportMill (Build Date: May-27-05, Version 9.0, JVM 23.0-b21, User Bigschottkeyd)
INFO [main-Designer-Startup] Starting module: Symbol Factory [+58828]
INFO [main-Designer-Startup] Initializing Scripting… [+59440]
INFO [main-Designer-Startup] Starting Tag System… [+59440]
ERROR [ProjectTag-Designer-Startup] Error creating tag binding.
java.lang.RuntimeException: Invalid tag path: ‘Root Container.MotorID/RUNNING’. Token PATH_SEPARATOR found after property name.
at com.inductiveautomation.factorypmi.application.binding.util.BindUtilities$Binder.createBoundExpression(BindUtilities.java:226)
at com.inductiveautomation.ignition.common.expressions.parsing.CUP$ELParser$actions.CUP$ELParser$do_action(ELParser.java:587)
at com.inductiveautomation.ignition.common.expressions.parsing.ELParser.do_action(ELParser.java:323)
at java_cup.runtime.lr_parser.parse(lr_parser.java:569)
at com.inductiveautomation.ignition.common.expressions.parsing.ELParserHarness.parse(ELParserHarness.java:22)
at com.inductiveautomation.factorypmi.application.sqltags.project.ProjectTag.createTagBinding(ProjectTag.java:83)
at com.inductiveautomation.factorypmi.application.sqltags.project.ProjectTag.startBindingImpl(ProjectTag.java:117)
at com.inductiveautomation.factorypmi.application.sqltags.project.ProjectTag.startBinding(ProjectTag.java:107)
at com.inductiveautomation.factorypmi.application.sqltags.ClientTagFolder.startBinding(ClientTagFolder.java:152)
at com.inductiveautomation.factorypmi.application.sqltags.project.ProjectTagManager.startup(ProjectTagManager.java:418)
at com.inductiveautomation.ignition.client.sqltags.impl.ClientTagManagerImpl.startup(ClientTagManagerImpl.java:145)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:986)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler$1.run(IgnitionDesigner.java:379)
Caused by: com.inductiveautomation.ignition.common.sqltags.parser.TagPathFormatException: Token PATH_SEPARATOR found after property name.
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathParser._parse(TagPathParser.java:197)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathParser.access$200(TagPathParser.java:25)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathParser$ParseFunction.apply(TagPathParser.java:387)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathParser$ParseFunction.apply(TagPathParser.java:383)
at com.google.common.collect.ComputingConcurrentHashMap$ComputingValueReference.compute(ComputingConcurrentHashMap.java:355)
at com.google.common.collect.ComputingConcurrentHashMap$ComputingSegment.compute(ComputingConcurrentHashMap.java:184)
at com.google.common.collect.ComputingConcurrentHashMap$ComputingSegment.getOrCompute(ComputingConcurrentHashMap.java:153)
at com.google.common.collect.ComputingConcurrentHashMap.getOrCompute(ComputingConcurrentHashMap.java:69)
at com.google.common.collect.ComputingConcurrentHashMap$ComputingMapAdapter.get(ComputingConcurrentHashMap.java:393)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathParser.parse(TagPathParser.java:168)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathParser.parse(TagPathParser.java:154)
at com.inductiveautomation.ignition.common.sqltags.parser.TagPathParser.parse(TagPathParser.java:113)
at com.inductiveautomation.factorypmi.application.binding.util.BindUtilities$Binder.createBoundExpression(BindUtilities.java:198)
… 13 more
INFO [main-Designer-Startup] Initializing UI… [+59487]
… 11 more
… 11 more
… 11 more
… 11 more
… 11 more
ERROR [TagProviderNode-SQLTags-TreeLoader-thread-1] Error loading tags underneath [default]
… 11 more
… 11 more
… 11 more
Have you tried to replace those tags to see if that resolves the problem?
One of the tags I was attempting to make was a motor description tag which had a string value that was an entire line long. After binding this to a custom property of a window, tag browsing failed, so I tried to delete the tags to fix the problem, I think I made things worse.
Replacing the tags did not help.
If you upload the backup to ticket number 7451, I should be able to quickly identify what’s causing the problem, and should be able to send you a few queries to run against the internal db to get it sorted out. It will also help us track down and fix our side of the problem.
Thanks,
[quote=“Colby.Clegg”]Hi,
Thanks,[/quote]
I restarted my server, this fixed my tag browser…
Sorry to take up your time with that one.
Yeah, I didn’t get an error immediately after loading the backup, so I figured it was an in-memory thing. However, I did manage to replicate it, so hopefully we can get some sort of fix in today.
When you’ve tried to delete elements from UDTs, are you deleting from the type, or the instance? It was brought to my attention last week that it’s currently possible to delete from under instances - which shouldn’t be possible. Doing this causes the problem you’ve reported. If that’s not what you were doing, let me know, otherwise just take care to delete from the data type, and not the instance.
Regards,
oh, yes. I was deleting from instancing too… that was probably it.
Thanks, I’ll remember not to do that any more
