I have a VERY basic tag event change script that I am trying to run and cannot understand why it does not work. All I am trying to do is write 0 to a memory tag when a certain tag value changes in the system. I also do not want it to run on an initial change.
Fired whenever the current value changes in value or quality.
Arguments:
tag: The source tag object. A read-only wrapper for obtaining tag
properties.
tagPath: The full path to the tag (String)
previousValue: The previous value. This is a "qualified value", so it
has value, quality, and timestamp properties.
currentValue: The current value. This is a "qualified value", so it has
initialChange: A boolean flag indicating whether this event is due to
the first execution or initial subscription.
missedEvents: A flag indicating that some events have been skipped due
to event overflow.
if not initialChange:
system.tag.write("[.]../Daily Actuals/Starting Count.value",0)
That being said, here is the really easy piece of script that I wrote. It works when I remove the initial change if statement, but otherwise throws an error and creates a bad tag value.
Has anyone else experienced this before?
