Tag Event Script - Print
Silly Question but desperate to know -
If I have a Tag like this -
Where Tag Event Script of test_A looks like -
Where would the this print go ?
I’ve checked gateway logs and designer console but no luck.
Tag Event Scripts - Ignition User Manual 8.0 - Ignition Documentation - suggests suggest it will be in the wrapper log file but that is the same as looking at the Logs right ?
It would show up in the wrapper.log file.
You can use a logger for it to display in the gateway logs too.
It does end up in the wrapper log file, but the Status > Logs webpage does not pick up print statements like that. In order for it to show up on the Logs webpage, you will want to use system.util.getLogger()
Logger thing just went out of my mind, thanks !
