I wrote a script, the purpose is to store the value of the last 5 changes of a tag, but now I found a strange phenomenon, when the measuring point changes once, the same value as the timestamp will be stored, help me
this is script
def setHistory_01(tag,value1,value2,timeStr):
if value1.value==value2.value:
return False
path='[alarm_tag_01]history/DI/DI_0_1/'+tag
dataSet=system.tag.read(path).value
pyDataSet=system.dataset.toPyDataSet(dataSet)
if len(pyDataSet)>4:
dataSet=system.dataset.deleteRow(dataSet, 0)
if len(pyDataSet)>5:
va=value1.value
tt= system.date.toMillis(timeStr)/1000
newRow=[va,tt]
dataSet=system.dataset.addRow(dataSet, newRow)
system.tag.write(path,dataSet)
The tag value is changed once, but the function is called more than once at the same time. Solve
help,thank
For starters, on this forum code should be placed inside three ` characters (or use the ‘preformatted text’ button) instead of put into quotes which doesn’t maintain formatting.
One potential issue I see is that you’re not filtering out ‘initialChange’ triggers. Therefore whenever you save the tag, restart the tag provider etc. your script will run which may not be what you want
In addition to running on tag edits or project edits (initialChange == True) as Nick noted, I vaguely recall there being a bug in tag editing leaving old code in place. If you aren’t running 8.0.16, you should upgrade. Also, you should edit your comments containing code to include the code formatting markers so it is readable. (Highlight all of your pasted code in the editor and click the </> button.)
thank
