I know I’m just overlooking something, but in my alarm pipeline I have a Switch block with at ag expression:
tag(“tag path”)
pointing to a Integer tag. On the outputs of the Switch block I have the values 0 and 1 (just testing for now) both of which go to separate notification blocks. The Switch block does not seem to evaluate the tag expression. If I bypass the switch the notification block triggers, but when I put the switch block in play it does not evaluate. I have even tried using toInt and toInteger around the tag() but it still doesn’t work.
Any pointers or clues? Thanks.
