Tag Historian Table not creating automatically
I’m having a problem with tag historian table after setting up a new database connection
java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:439)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:395)
at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:802)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:436)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:186)
at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:521)
at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:205)
at oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:861)
at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1145)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1267)
at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3449)
at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3493)
at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1491)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:93)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.executeQuery(SRConnectionWrapper.java:948)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper.runPrepQuery(SRConnectionWrapper.java:166)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.loadOrCreateSystemDetails(TagHistoryDatasourceSink.java:403)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.getSystemDetails(TagHistoryDatasourceSink.java:365)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.getProviderId(TagHistoryDatasourceSink.java:340)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.storeScanClassSet(TagHistoryDatasourceSink.java:472)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.storeDataToDatasource(TagHistoryDatasourceSink.java:458)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.storeToDatasource(AbstractDatasourceSink.java:137)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.storeData(AbstractDatasourceSink.java:115)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AggregateSink.storeData(AggregateSink.java:170)
at com.inductiveautomation.ignition.gateway.history.forwarders.ForwarderThread.run(ForwarderThread.java:149)
the database connection says it is valid but it gives an error in the log
Did you ever resolve this? I’m experiencing the same error with Oracle 18c.
I can create/drop tables and views from the DB Query Browser but the tag historian is not creating tables.
I was able to resolve this by deleting sequences created for tag history tables. There was existing sequences like SQLTH_DRVSEQ, so deleting the sequence in oracle and restarting the Tag History module correct my errors for a new database connection.
