Tag History Configuration - max time between records
I am trying to setup a tag that does not change often, to save down at least once a day. I have been fighting with this for a couple days and cannot seem to configure it right apparently, because I can go back into the query browser to look at the entries on the tag and it only shows on change. Skipped several days entirely. Any suggestions? I have attached a screenshot of the configuration.
Ignition Platform 7.9.12
it is value between 1 and 10. May not change to a different value but around once a week on average, but want a record at least once a day for reporting.
I see. If you change your Timestamp Source to System your Max time between records setting will be respected. Cheers!
More info about configuring Tag History:
https://docs.inductiveautomation.com/display/DOC79/Configuring+Tag+Historian#ConfiguringTagHistorian-MaxTimeBetweenRecords
Ah ha, It works! Thank you!
