Tag History Dataset values outside selected range
Hello,
I am facing an issue when trying to display history on a time series chart. The time range that I want to display is defined using the chart range selector, and I use the start and end dates as the boundaries in the Tag History Binding.
However, the returned dataset always contains two values that are outside the selected range. I would like to understand why this happens.
Below are screenshots of my settings. Could you please let me know whether I am doing something wrong? If any additional information is needed, I can provide it afterwards.
I am using ignition 8.3.4.
Best regards,
Žiga Šraj
This is a bug with a fix I believe in 8.3.6...
