I’m curious about the best way to store parameters in an SQL Server database. In the beginning, I used the Tag Historian to save data, and Ignition automatically created its own database architecture, storing each parameter as a row and partitioning the tables by month.
Later, I ran into a problem: in production, they wanted to save a group of parameters per batch. I tried using Transaction Groups, but it became messy because I ended up creating a separate table for each position in the factory. To display the data, I first had to know the position in the factory and then write a specific query for each one.
Because of this, I decided to copy the same architecture used by the Tag Historian. I now save all parameters in a batch, linked by a column that indicates the batch_id. The problem is that when I try to display the data in a table, I need to pivot the results so they appear as columns instead of rows. Ignition does this automatically for historian tags, but in my case I need to do it manually in the SELECT query. Performance becomes terrible when large amounts of data are involved — it can take minutes to load the table, and I often get timeouts.
Is there a better way to pivot data in a table? I’ve read in some SQL forums that Excel has more powerful tools for pivoting than SQL, but what about Ignition?
You can write whatever you want to process data from a database query in Jython, it's justa programming language, and it will do what you write. I regularly write code that processes data that I have grabbed from a massive database with simple filters. This means that the client is the one that deals with the processing overhead.
The standard approach here would be to have only one table for all positions in the factory but add a column for the position name. This way you can retrieve data for that position in the SQL:
SELECT ....
FROM ...
WHERE
position = :positionNum
You would pass positionNum as a query parameter.
This method would also allow you to create aggregate reports for all or multiple lines without having to UNION query results from multiple tables.
I think what op means is that each machine has different numbers of parameters to store, which means storing thm in a tall table rather than wide, but then there’s the additional effort required to bring it back to wide for display purposes
Yes exactly this is what I exactly mean.
I have already created a tall table partitioned by date where I have copied historian tag history table architecture just adding 2 extra columns: Batch_id and position_id.
My question is how to pivot (transpose) this sql table when showing in a power table in a efficient way. I have already tried using pivot in sql query, but as I said performance is terrible for positions with a lot of parameters (it means a lot of columns). I have also tried to transpose my table looping the select result and transforming it to a table with columns, but I get same bad result as with the other solution.
Have you got any indexes on your tables? I would use EXPLAIN (check the right term to use for your DB) to get the execution plan and post that here
