Tag history for document tags failing
I have a document tag for which I am trying to keep tag history, and it is failing. This is in the log. Is tag history for document tags supported? Ignition 8.1.19. Thanks
java.lang.RuntimeException: java.sql.SQLSyntaxErrorException: (conn=8) Could not set parameter in setObject, could not convert: class com.inductiveautomation.ignition.common.document.Document to 12
at com.inductiveautomation.ignition.common.functional.FragileConsumer.lambda$wrap$1(FragileConsumer.java:47)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.accept(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
at java.base/java.util.stream.Streams$StreamBuilderImpl.forEachRemaining(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$Head.forEach(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$7$1.accept(Unknown Source)
at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.forEach(Unknown Source)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.storeToDatasource(AbstractDatasourceSink.java:186)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.storeData(AbstractDatasourceSink.java:156)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AggregateSink.storeData(AggregateSink.java:180)
at com.inductiveautomation.ignition.gateway.history.forwarders.ForwarderThread.run(ForwarderThread.java:147)
Caused by: java.sql.SQLSyntaxErrorException: (conn=8) Could not set parameter in setObject, could not convert: class com.inductiveautomation.ignition.common.document.Document to 12
at org.mariadb.jdbc.internal.util.exceptions.ExceptionFactory.createException(ExceptionFactory.java:62)
at org.mariadb.jdbc.internal.util.exceptions.ExceptionFactory.create(ExceptionFactory.java:173)
at org.mariadb.jdbc.BasePrepareStatement.setInternalObject(BasePrepareStatement.java:1140)
at org.mariadb.jdbc.BasePrepareStatement.setObject(BasePrepareStatement.java:836)
at org.apache.commons.dbcp2.DelegatingPreparedStatement.setObject(DelegatingPreparedStatement.java:529)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.setObject(SRConnectionWrapper.java:1096)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink$TagInsert.populatePreparedStatement(TagHistoryDatasourceSink.java:1202)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink$BatchedTagInsert.insert(TagHistoryDatasourceSink.java:1241)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.insertTagValues(TagHistoryDatasourceSink.java:1042)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.storeScanClassSet(TagHistoryDatasourceSink.java:542)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.storeDataToDatasource(TagHistoryDatasourceSink.java:517)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.lambda$storeToDatasource$2(AbstractDatasourceSink.java:186)
at com.inductiveautomation.ignition.common.functional.FragileConsumer.lambda$wrap$1(FragileConsumer.java:45)
... 18 common frames omitted
Not supported. Nor for datasets.
Thanks Phil
