Hi there,
I have a tag with below history setting.
The tag value will be reset at 6:00 PM everyday, I need to know the maximun value around 6:00 PM.
Raw data looks good from table above, but if I change the table data setting to maximun, it gives a result 0, I believe in this time range I selected should get a result 39.
But if I change the date range before 6:00PM, I can get the right value.
The same result if I use script
system.tag.queryTagHistory(paths=tagPathList, startDate=startTime, endDate=endTime, returnSize=1, aggregationMode="Maximum", returnFormat='Wide',noInterpolation=0,includeBoundingValues=1)
Any idea about the situation?
Thanks in advance.
