See above is a snippet of a screen I am working on with some tag errors. I use an embedded view and a numbering system to indirectly tag bind them. All the tags are coming into the tag browser correctly. So, the issue is not all the tags are coming in correctly, because when I reload the page, it will be a different set of tags that is incorrect instead of the ones in the attached image meaning the actual tag path is not the issue. Looking around other forums it seems to possibly be an error on the PLC side. I could not find a concrete fix to the issue though. The processor of the PLC is an Allen Bradley 7 Series (I can find the exact model if that is needed). If anyone has experienced this issue and found a solution or have an ideas I would greatly appreciate
