I made a tag and set an alarm, but ended up deleting the tag while the alarm was active. Now my alarms table still shows it as active even though it's deleted. It gives this text "Tag missing or removed since alarm active". How can I clear this alarm? Do I need to restart the server?
Not the whole server, but just the gateway service. And not just a simple restart.
Stop the Ignition service
Find the
.alarms....file in the install folder that perpetuates alarm status through restarts and delete it. -
Restart the Ignition service
Thanks that worked!
There's a "Solution" link below each answer. Hit the one below Phil's answer so that the question shows up as solved on the main index and to credit whoever solved it!
Welcome to the forum.
