Since upgrading from v7.9.5 to v7.9.14, I keep seeing ‘Tag Not Found’ when clicking on tags in the tag browser. Not every time, but periodically. The only way to fix it (within the Designer, I didn’t try restarting the tag provider) is to create a new folder/tag.
Exception in thread "AWT-EventQueue-2" java.lang.NullPointerException
at com.inductiveautomation.ignition.designer.sqltags.config.ui.TagObjectEditorPanel$EditMode.getModeForTag(TagObjectEditorPanel.java:1542)
at com.inductiveautomation.ignition.designer.sqltags.config.ui.TagObjectEditorPanel$EditMode.getModeForTags(TagObjectEditorPanel.java:1531)
at com.inductiveautomation.ignition.designer.sqltags.config.ui.TagObjectEditorPanel.setEditObjects(TagObjectEditorPanel.java:250)
at com.inductiveautomation.ignition.designer.sqltags.config.ui.TagObjectEditor.finishLoad(TagObjectEditor.java:184)
at com.inductiveautomation.ignition.designer.sqltags.config.ui.TagObjectEditor$LoadTask$1.run(TagObjectEditor.java:253)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
On clicking on other further tags, I then start seeing errors from the seeq module:
10:58:46.127 [AWT-EventQueue-2] ERROR com.seeq.ignition.designer.LaunchSeeqTagBrowserMenuItem - Error determining trend items from path
com.inductiveautomation.ignition.common.sqltags.exceptions.TagNotFoundException: null
at com.seeq.ignition.v7.common.IgnitionModuleUtilities.trendItemFromPath(IgnitionModuleUtilities.java:114)
at com.seeq.ignition.designer.LaunchSeeqTagBrowserMenuItem$2.valueChanged(LaunchSeeqTagBrowserMenuItem.java:165)
at javax.swing.tree.DefaultTreeSelectionModel.fireValueChanged(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.notifyPathChange(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.setSelectionPaths(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.setSelectionPath(Unknown Source)
at javax.swing.JTree.setSelectionPath(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI.selectPathForEvent(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.handleSelection(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.mousePressedDND(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.mousePressed(Unknown Source)
at java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at com.jidesoft.docking.DockingUtils.a(Unknown Source)
at com.jidesoft.docking.DefaultDockingManager.handleEvent(Unknown Source)
at com.jidesoft.docking.DefaultDockingManager$55.eventDispatched(Unknown Source)
at java.awt.Toolkit$SelectiveAWTEventListener.eventDispatched(Unknown Source)
at java.awt.Toolkit$ToolkitEventMulticaster.eventDispatched(Unknown Source)
at java.awt.Toolkit.notifyAWTEventListeners(Unknown Source)
at java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
