system.tag.write(’[Client]input/’ + section + ‘_value’, value)
whereas ‘section’ is a string variable.
Fails with:
TypeError: cannot concatenate ‘str’ and ‘com.inductiveautomation.ignition.common.sqltags.BasicTagValue’ objects
as this is being used in a a parameterized window, this would save me a complex switch style case selection and maintaining a hard coded reference to sections in this window.
I assumed this would work because the quoted string appears to be, well, a string…
I solved this, it was created by me.
I had assumed that the return of a tag.read operation on a string tag would be the string value.
The BasicTagValue was however an object that contained the quality and the value.
I had assumed the error message was telling me that the BasicTagValue was what I was trying to combine with my string path variable, instead it was telling me that the string tag path could not be combined with my retrieved value.
So when I cast my tag return to string I was actually left with the string ‘[,]’
using tag.read().value retrieved the string only portion, and then the concatenated path worked as expected…
All fixed now, just a learning experience.
[quote=“Sir Hacksalot”]
The BasicTagValue was however an object that contained the quality and the value.[/quote]
This mistake is so common that it should be some kind of initiation into the Ignition user brotherhood
Glad you figured it out.
