ns=1;s=[CLX]Global.M{MotorNumber}.AMPS for the tag mentioned unable to find the path from where it is reference Eg: [CLX]Global.M from where it is referencing i am trying to understand from demo projects.
So this is an OPC path from a demo project? What's the question, you just want to know what it's doing?
There is a parameter named MotorNumber. Then in the PLC, in this case a ControlLogix, there are tags like Global.M1.AMPS. Assuming there was a motor 10, you would enter 10 in the parameter.
There are many examples in the docs, perhaps start here.
OK Thank You for reply.
In My case control logix device is not available in my Gateway Device configuration and all simulators are visible and i can identify them but physical PLC was not configured.
Thank You.
I don't know what demo you are referring to, but I'm basing things from the name of the tag provider, CLX. That is typically the abbreviation for ControlLogix. It could be simulation, or really anything.
