Is there something obvious I’m not doing correctly?
The two cases below don’t match:
CASE 1:
Script in a custom object “stationTagRoot” (Expression binding with Script Transform):
stationNum = 701
try:
tagPath = '[default]Plant/Line/'
browse_result = system.tag.browse(tagPath, {'name':str(stationNum)}).getResults()
stationTagRoot = browse_result[0]
except:
stationTagRoot = {"fullPath": "nope","hasChildren": bool(0), "name": "nope", "tagType": "nope" }
return stationTagRoot
The script associated with the onActionPerformed Event a button:
system.perspective.navigate(view = 'Sandbox Subview', params = {'stationTagRoot':self.custom.stationTagRoot})
Below is the correct behavior that I’m getting when the
{"fullPath":"[default]Plant/Line/701","hasChildren":true,"name":"701","tagType":"Folder"}
CASE 2:
Script associated with the onActionPerformed Event a button:
stationNum = 701
try:
except:
system.perspective.navigate(view = 'Sandbox Subview', params = {'stationTagRoot':stationTagRoot})
RESULT in a label in the Sandbox Subview:
{"fullPath":{"prop":null,"pathParts":["Plant","Line","701"],"source":"default"},"hasChildren":true,"name":"701","tagType":"Folder"}
The object put int the value of the “fullPath” key is not what I expected. The rest matches
