I have been having some weird issues pop up occasionally where the tag provider wont show me any tags at all. It usually happens after trying to edit a tag. just now I tried adding a custom email message to a tag. when I clicked ok to close the tag editing window, it popped up a window that says executing task, then it errors out. after that is when the tag provider starts acting goofy in the designer. It doesnt do this every time, but I have to restart the server to fix the issue. I have also been getting alot of the executing tasks popup windows and error performing asynchronous tag errors. not sure if it is all related.
this is the error that it throws up:
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Gateway Error 60001: Error executing asynchronous task.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:279)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:249)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:214)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:656)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager.editTags(DatasourceTagManager.java:379)
at com.inductiveautomation.ignition.client.sqltags.impl.ClientTagManagerImpl.editTags(ClientTagManagerImpl.java:271)
at com.inductiveautomation.ignition.designer.sqltags.editor.TagEditorPanel$EditTask.run(TagEditorPanel.java:351)
at com.inductiveautomation.ignition.client.util.gui.progress.ClientProgressManager$ClientRunningTask.run(ClientProgressManager.java:433)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:520)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.util.concurrent.TimeoutException: Results for asynchronous rpc call were not received within the specified amount of time [60000 ms] for task ‘da05254f-2d46-461f-9cb8-0286d42883a8’
at com.inductiveautomation.ignition.client.util.gui.progress.ClientProgressManager$RunningTask.waitForResult(ClientProgressManager.java:375)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:237)
… 15 more
Ignition v7.2.5-beta3 (b63)
Java: Sun Microsystems Inc. 1.6.0_23
