Tag pulling data from API Rest
I’m wondering if it’s possible to set a tag to pull data from an API Rest.
I would like to, such I get data from a SQL for instance, get the tag value from an API Rest?
Is this possible?
Were you able to figure out how to pull a tag value from an API Rest?
If so would you share how it is done? I am starting a project where I will need to do this and haven’t found any resources on it.
Thank you
There isn’t an HTTP tag type or anything like that, but a timer script that polls your API and writes the results into memory tags seems like a pretty easy approach.
https://docs.inductiveautomation.com/display/DOC81/system.net.httpClient
Thank you Kevin! That will help immensely
