Hi!
I have some OPC tags connected to an Allen Bradley device using the CompactLogix Legacy driver, and some tags work, but other tags (especially booleans) give me an error code Error_Configuration("Bad_AttributeIdInvalid: The attribute is not supported for the specific node.")
I've confirmed the tags exist and there aren't any typos, and don't appear to be any special R/W config on the PLC end.
I tried referencing this webpage:
Quality Codes and Overlays | Ignition User Manual but that doesn't cover this specific error.
Any advice would be appreciated ![]()
EDIT: I found it, my OPC Item Path was missing the Global.{tag name} after the device driver
