I understand results returned are 3 components per Tag. After looking at the help, I just don’t understand how to just pull/use the xxx.value
So, if we have values = system.tag.readAll(taglist),
what is the scripting/format equivalent to the original individual read?
old way:
myVal=system.tag.read(“xxxx”).value
new way??
I understand the info for the first tag is values[0] I guess but how to grab only the value, and use it as an integer value say ?
is it values[0][0] or ???
Use values[0].value, values[1].value, etc. I often use a list comprehension in a one-liner to get just the values. Like so:
values = [x.value for x in system.tag.readAll(listOfTags)]
This is only suitable when you don’t need the qualities, of course.
To answer your question, it would be values[0].value
pturmel's method grabs just the values up front. Then it would be values[0]
EDIT: Apologies to pturmel. should have read a bit closer! Time for more coffee!
