how can I read a TAG with dynamic path in SFC transition?
Please any suggestions.
example of Non dynamic works fine:
{[default]Assembly_Cells/PAC_S1/OPC/Line_Status}
I want tho have "PAC_S1" part dynamic. Stored in chart variable.
thank you
thank you
It is an expression, so you can use the tag() expression:
https://docs.inductiveautomation.com/display/DOC81/tag
it is working:
tag("[default]PreAssembly_Cells/"+{chart.StationName}+"/OPC/Line_Status")
thank you!
