Tag replication in Ignition
Is there any replication feature available in Ignition that replicate tags located in one Ignition to another like PI to PI interface from Aveva (OSI Soft)
Not familiar with Pi, but you can set up Gateway network connections and remote tag providers to access tags on other gateways.
@michael.flagler Do you have any reference to know more about this setup?
Go through this list of videos.
Maybe this is another good aproach to get the Tags from my OPC-DA connections. This way I can keep both gateways, Vision and Perspective in different servers.
Keep in mind that tags update no faster than 1000ms on the gateway network, so if you need faster updates than 1 second you'll have to have them on the same gateway.....or use the OPC-UA server in the one server and set up an OPC-UA client on the other.
I guess that would be enough. I will study both options (common gateway on same server or gateway network) for my OPC-DA tags connection and come to a conclusion. Thanks!
Remote Tag Provider Video at Inductive University
