Tag script help
First time doing a tag script
Vision
Version: 8.1.17
Background: I have AB PLC’s 5, 500 and 5000 that will all need to have the clock synced to within a few seconds. I want the following tag to be a “call” from the PLC’s at first scan then I will run it every hour to keep time.
I can toggle the plc and see the tag go true and I can set numbers in the write tag and see them change in the plc. The Gateway_Seconds tag is showing seconds. Can’t figure out what I am doing wrong or where to look to figure it out.
I have a Bool UDT from a plc with the following script.
Fired whenever the current value changes in value or quality.
Arguments:
	tag: The source tag object. A read-only wrapper for obtaining tag
	     properties.
	tagPath: The full path to the tag (String)
	previousValue: The previous value. This is a "qualified value", so it
	               has value, quality, and timestamp properties.
	currentValue: The current value. This is a "qualified value", so it has
	initialChange: A boolean flag indicating whether this event is due to
	               the first execution or initial subscription.
	missedEvents: A flag indicating that some events have been skipped due
	              to event overflow.
gatesec = system.tag.readBlocking("[default]Gateway_Seconds")[0].value
if currentValue.value == true:
	system.tag.writeBlocking(["[.]Clock Second Write"],["gatesec"])
Get rid of the quotes to reference the variable, otherwise you’re trying to write the string "gatesec".
So like
	system.tag.writeBlocking(["[.]Clock Second Write"],[gatesec])
Still a no go. Adding the quotes was my last attempt before asking for help. I am not getting any errors that I see but the udt opc tag Clock Second Write won’t change.
Do you see anything in your gateway logs?
writeBlocking provides a list of result codes back. Try doing this to in your script console to see what is going wrong -
results = system.tag.writeBlocking(["[.]Clock Second Write"],[gatesec])
for result in results:
    print result.diagnosticMessage
And you should at least what is going wrong here.
Thank you very much. Knowing where to find the errors was the key. This was the answer.
if currentValue.value == 1:
Oh I should have caught that. For python its True/False. true isn’t anything, so you’re script was probably erroring out at the comparison line.
