nifemi
1
I’ve just upgraded to 7.8… and all my tags have come up with null values and bad Quality:
[Bad_NoDataAvailable] No data is currently available for reading from a non-blocking stream
I’ve been over all the tag properties in the designer, and I cant find anything wrong… help is appreciated.
Thanks.
nifemi
2
Finally got the tags looking good, but after a few hours it all went pear shaped again. this time:
Bad_ConditionAlreadyShelved
Goodbye, its back to 7.7.5 for me
[quote=“nifemi”]Finally got the tags looking good, but after a few hours it all went pear shaped again. this time:
[/quote]
That one usually means trial expired (there’s no appropriate StatusCode in UA, so a rarely used one was chosen to represent it).
nifemi
4
[quote=“Kevin.Herron”][quote=“nifemi”]Finally got the tags looking good, but after a few hours it all went pear shaped again. this time:
[/quote]
That one usually means trial expired (there’s no appropriate StatusCode in UA, so a rarely used one was chosen to represent it).[/quote]
ooh, seemed much more ominous.
nifemi
5
A fresh install seems to have taken care of things, but I never did find the original problem.
It would have been nice to post what the fix was for the OP issue… I’m getting the same error (no data from non-blocking stream)
Did you ever get an answer Im having that issue
