Tag Value Changed Script : only works with override
Dear experts.
I have a UDT with a tag value changed script.
When I create an instance of this UDT the script doesn’t get executed (I start with a log.trace)
When I override the Value Changed script but don’t make any actual changes it suddenly starts to work.
Any idea what might cause this behaviour?
A good starting point:
You might check your gateway Status / Diagnostics / Running Scripts page to quickly visualize any long running scripts.
You might also find Tag Diagnostics useful. Right-click on a tag –> View Diagnostics to check for anything out-of-norm.
