Tag Version Control Module
Hello All,
A while back I published (A bit quietly) a module that could enable some better version control of tags, and I am not sure if I ever published it here. So I figured I would share it for all of those that will not have access to 8.3 for some time!
Currently it supports the following features:
  1. Allows REST endpoints that can do tag imports/exports/edits based off of provided JSON content.
  2. Adds the ability to auto-import tags based off of a config file located in the gateways data directory. This will allow a gateway to import a collection of exported tags on startup automatically.
  3. Adds some designer UI controls to trigger the import/export by hand if desired.
  4. Export/Import tags through a heirarchical folder structure that is a bit easier to version control than just a single mega-JSON file. This exports the tags in the same folders structure they represent in the tag provider, and exports an individual file per tag, or per UDT instance.
I just updated the current release to v2.0.0 at: GitHub - design-group/ignition-tag-cicd-module: An Ignition Module to add features that enhance CICD capabilities for tags.
To configure the auto-import on startup just add a config to data/modules/tag-cicd/export-config.json with a structure matching the following
    "provider": "default",
    "baseTagPath": "", # Implies the root of the provider, and will include UDTs by default in `_types_`
    "sourcePath": "data/tags",
    "exportMode": "individualFiles",
    "collisionPolicy": "o"
Keep in mind, the sourcePath referenced in the file is a path from the perspective of the gateway, so reference paths start at the Ignition installation directory. If using the import/export REST APIs this is the same, they are from the perspective of the gateway every time, not your host.
To export based off that saved config file, go ahead and press the export button located in the toolbar:
tag-cicd-toolbar
And then select the tags based off what you want to export:
Keep in mind, this will only work after you have setup the config file. Without that, it wouldn't know what to export or where!
If anyone finds anything, or would like specific features, feel free to create an issue for them.
We'll see what happens after 8.3 with the new file system content for tags, my understanding is this does things a bit differently, so it may still have a place there and time will tell!
EDIT: I updated this because I overhauled some things, and also made it more 8.3 forward compatible!
This looks great!
Do you have docs for the underlying json schema anywhere?
The schema for the tag exports is the same one as a native tag export
However the schema for the config file, not necessarily but I can probably add that to the readme pretty easily.
To anyone curious, I went deep and built out a whole User interface in the Designer to Add/Edit/Delete these configurations, etc. and I documented the heck out of everything
https://design-group.github.io/ignition-tag-cicd-module
Here is the Tag Configuration Manager UI
And configuration tool to define new ones
There is an absolute ton of documentation now, and so feel free to leave any issues and let me know of anything that might be missing.
