Only 3 images are attached.
All of them are memory tags.
When TP is selected, the W/D box should not be visible.
If TPOn, TPOnOnF, or WD is selected, the W/D box should be visible.
Even if only TPOn is selected or only TPOnOnF is selected, the W/D box should be visible.
Similarly, if only WD is selected, the W/D box should be visible.
tag("[default]" + {LVOpenClose.tagPath} + "/TPOn" + "/WD" + "/TPOnOnF")
