Any idea why this would happen? I believe our PLC is a little overwhelmed with connections at the moment, but I’m not sure why the designer would disconnect from the gateway.
16:48:37.970 [ForkJoinPool.commonPool-worker-3] WARN com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Connection to Gateway lost, due to exception.
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:341)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:501)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:273)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:905)
at com.inductiveautomation.ignition.client.tags.impl.GatewayTagInterface$GatewayProviderProxy.lambda$writeAsync$1(GatewayTagInterface.java:311)
at java.base/java.util.concurrent.CompletableFuture$AsyncRun.run(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$AsyncRun.exec(Unknown Source)
at java.base/java.util.concurrent.ForkJoinTask.doExec(Unknown Source)
at java.base/java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(Unknown Source)
at java.base/java.util.concurrent.ForkJoinPool.scan(Unknown Source)
at java.base/java.util.concurrent.ForkJoinPool.runWorker(Unknown Source)
at java.base/java.util.concurrent.ForkJoinWorkerThread.run(Unknown Source)
Caused by: java.net.SocketTimeoutException: Read timed out
at java.base/java.net.SocketInputStream.socketRead0(Native Method)
at java.base/java.net.SocketInputStream.socketRead(Unknown Source)
at java.base/java.net.SocketInputStream.read(Unknown Source)
at java.base/java.io.BufferedInputStream.fill(Unknown Source)
at java.base/java.io.BufferedInputStream.read1(Unknown Source)
at java.base/java.io.BufferedInputStream.read(Unknown Source)
at java.base/sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
at java.base/sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.base/java.net.HttpURLConnection.getResponseCode(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:421)
… 11 common frames omitted
16:48:38.011 [ForkJoinPool.commonPool-worker-3] INFO tags.subscriptions - Changing connected quality to ‘Bad_Stale’
16:48:38.021 [ForkJoinPool.commonPool-worker-3] INFO Scripting.ScriptManager.PyComponentWrapper - Pausing scripts…
16:48:38.021 [ForkJoinPool.commonPool-worker-3] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Starting reconnect thread.
