I am running the Module Allen-Bradley Drivers 1.4.0 (b196) on Ignition 7.4.1 communicating with an AB CompactLogix via Ethernet. Gateway is running on Server 2008R2.
We clearly have a situation where a system.tag.write() is not executing properly (the value does not get written to the PLC). I am wondering if I should simply update the Allen-Bradley drivers version.
We cannot simply upgrade Ignition since it is a validated system. We can, however, upgrade the ethernet driver if needed. If so, what driver should I be upgrading to if I am only using 7.4.1?
Below is the wrapper.log contents from the time of the issue. Thanks
INFO | jvm 1 | 2015/05/07 15:41:14 | ERROR [CompactLogix ] [15:41:14,714]: [CompactLogix] Key equals 0: length=498, [ 70 00 DA 01 1F BD 02 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 A1 00 04 00 EE 7A 6F 3C B1 00 C6 01 00 00 8A 00 00 00 01 00 04 00 CC 00 00 00 00 AA C0 41 D0 4C BD 41 F0 20 C0 41 90 17 F1 41 D0 97 BF 41 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 6B 13 75 42 9F A2 7F 42 EF E0 77 42 EA D8 75 42 EF 1C 78 42 00 00 20 42 24 0C 96 42 60 1D 80 42 40 3E C9 41 20 84 C7 41 20 6C C9 41 30 BE C6 41 30 77 C7 41 30 CC C9 41 B0 8C C7 41 60 2E C9 41 D0 3C C7 41 70 F9 C6 41 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 28 70 42 CF 55 6F 42 00 00 00 00 00 00 00 00 85 98 72 42 82 EB 70 42 00 00 00 00 00 00 00 00 02 26 71 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 97 F7 41 98 9A 5F 42 00 00 00 00 00 00 00 00 50 5E 22 42 00 42 F1 41 08 8A 20 42 C0 B4 A0 40 00 00 00 00 00 A3 CF 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 78 C4 B4 41 00 00 00 00 00 00 00 00 00 00 00 00 43 AD 95 42 36 B7 82 42 00 E4 97 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 75 DD 7A 42 5F 94 F5 41 7E 73 7E 42 2F 31 F3 41 B0 B5 B2 41 80 51 B3 41 80 00 12 42 00 00 00 00 80 D8 53 C0 E0 68 94 41 00 00 00 00 00 00 00 00 B2 1A C3 C2 90 5D B3 41 00 00 00 00 00 00 00 00 B8 0B 02 42 80 62 27 40 00 00 00 00 00 00 00 00 ]
INFO | jvm 1 | 2015/05/07 15:41:14 | WARN [BasicRequestCycle ] [15:41:14,714]: Message arrived for key “0” but no request found.
INFO | jvm 1 | 2015/05/07 15:41:20 | Running Alarm Reset Int Routine. Alarm alarmResetInt is = 2
INFO | jvm 1 | 2015/05/07 15:41:20 | Wrote a 0 to the resetInt for sensor 90
INFO | jvm 1 | 2015/05/07 15:41:20 | WARN [TimeoutDaemon ] [15:41:20,477]: ScheduledRequest[[ABControlLogixReadRequest]] request with key “10713” failed due to timeout.
INFO | jvm 1 | 2015/05/07 15:41:20 | WARN [TimeoutDaemon ] [15:41:20,478]: ScheduledRequest[[ABControlLogixReadRequest]] request with key “10714” failed due to timeout.
INFO | jvm 1 | 2015/05/07 15:41:21 | Running Alarm Reset Int Routine. Alarm alarmResetInt is = 2
INFO | jvm 1 | 2015/05/07 15:41:21 | Wrote a 0 to the resetInt for sensor 213
INFO | jvm 1 | 2015/05/07 15:42:36 | INFO [LocalDBManagerImpl ] [15:42:36,052]: Creating auto-backup of internal database “settings”…
INFO | jvm 1 | 2015/05/07 15:42:36 | INFO [ENGINE ] [15:42:36,053]: checkpointClose start
INFO | jvm 1 | 2015/05/07 15:42:36 | INFO [ENGINE ] [15:42:36,082]: dataFileCache commit start
INFO | jvm 1 | 2015/05/07 15:42:36 | INFO [ENGINE ] [15:42:36,105]: checkpointClose end
INFO | jvm 1 | 2015/05/07 15:42:36 | INFO [ENGINE ] [15:42:36,105]: Initiating backup of instance ‘settings’
INFO | jvm 1 | 2015/05/07 15:42:36 | 1 / 4 settings.properties…
INFO | jvm 1 | 2015/05/07 15:42:36 | 2 / 4 settings.script…
INFO | jvm 1 | 2015/05/07 15:42:36 | 3 / 4 settings.data…
INFO | jvm 1 | 2015/05/07 15:42:36 | 4 / 4 settings.lobs…
INFO | jvm 1 | 2015/05/07 15:42:36 | INFO [ENGINE ] [15:42:36,637]: Successfully backed up instance ‘settings’ to ‘C:\Program Files\Inductive Automation\Ignition\data\db\autobackup\db_20150507_154236.tar.gz’
INFO | jvm 1 | 2015/05/07 15:42:36 | INFO [LocalDBManagerImpl ] [15:42:36,642]: Created auto-backup of internal database “settings” in 590 ms
