I have this warning that keeps appearing in my log, however nothing shows in the store and forward as quarantined… I believe this was generated from an eariler issue where I was trying to write data to a MSSQL using a MySQL translator, so I’m assuming everything is hung. I just don’t know where to look to clear the errors.
http://forum.inductiveautomation.com/t/taghistorydatasourcesink-error-initializing-data-sink/3636
java.lang.NullPointerException: null
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.checkTables(TagHistoryDatasourceSink.java:1043)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.initialize(TagHistoryDatasourceSink.java:237)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.lambda$initialize$0(TagHistoryDatasourceSink.java:249)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
