TagHistoryManager().queryHistory : java.lang.IllegalArgumentException: Comparison method violates its general contract!
Ignition 8.1.0
I use TagHistoryManager().queryHistory to retrieve some history data from a module (gateway scope)
Sometimes, I have the following exception:
ResultWriter	03Dec2020 16:20:20	Error executing historical tag read.
what does it mean ?
            BasicTagHistoryQueryParams tagHistoryQueryParams = new BasicTagHistoryQueryParams();
            // /!\ Flag.and() doesn't mutate the object, it returns a new one
            Flags flags = Flags.of(TagHistoryQueryFlags.BOUNDING_VALUES_YES,
                    TagHistoryQueryFlags.NO_INTERPOLATION,
                    TagHistoryQueryFlags.NO_SCANCLASS_VALIDATION,
                    TagHistoryQueryFlags.NO_CACHE,
                    TagHistoryQueryFlags.NO_PREPROCESSED_DATA);
            tagHistoryQueryParams.setQueryFlags(flags);
            tagHistoryQueryParams.setReturnSize(-1);
            tagHistoryQueryParams.setAggregationMode(AggregationMode.LastValue);
            tagHistoryQueryParams.setStartDate(startDate);
            tagHistoryQueryParams.setEndDate(endDate);
            // Tall : Column format is fixed at "path, value, quality, timestamp".
            tagHistoryQueryParams.setReturnFormat(ReturnFormat.Tall);
            tagHistoryQueryParams.setPaths(paths);
            BasicStreamingDataset streamingDataset = new BasicStreamingDataset();
            logger.debug("queryHistoryDataChanges() - begin");
            this.gatewayContext.getTagHistoryManager().queryHistory(tagHistoryQueryParams, streamingDataset);
at java.base/java.util.ComparableTimSort.mergeHi(Unknown Source)
at java.base/java.util.ComparableTimSort.mergeAt(Unknown Source)
at java.base/java.util.ComparableTimSort.mergeCollapse(Unknown Source)
at java.base/java.util.ComparableTimSort.sort(Unknown Source)
at java.base/java.util.Arrays.sort(Unknown Source)
at java.base/java.util.ArrayList.sort(Unknown Source)
at java.base/java.util.Collections.sort(Unknown Source)
at com.inductiveautomation.gateway.tags.history.query.DatasourceQueryExecutor.runSpecialValueQuery(DatasourceQueryExecutor.java:864)
at com.inductiveautomation.gateway.tags.history.query.DatasourceQueryExecutor.readSeedValues(DatasourceQueryExecutor.java:699)
at com.inductiveautomation.gateway.tags.history.query.DatasourceQueryExecutor.primeRead(DatasourceQueryExecutor.java:885)
at com.inductiveautomation.ignition.gateway.sqltags.history.query.AbstractHistoryLoader.startReading(AbstractHistoryLoader.java:118)
at com.inductiveautomation.ignition.gateway.sqltags.history.query.AggregateHistoryQueryExecutor.startReading(AggregateHistoryQueryExecutor.java:85)
at com.inductiveautomation.ignition.gateway.sqltags.history.query.HistoryWriter.readData(HistoryWriter.java:312)
at com.inductiveautomation.ignition.gateway.sqltags.history.query.HistoryWriter.execute(HistoryWriter.java:230)
at com.inductiveautomation.ignition.gateway.sqltags.history.TagHistoryManagerImpl.queryHistory(TagHistoryManagerImpl.java:538)
at com.bouyguesenergiesservices.ignition.gateway.replay.tag.QueryHistoryTall.queryHistoryDataChanges(QueryHistoryTall.java:1108)
at com.bouyguesenergiesservices.ignition.gateway.replay.tag.QueryHistoryTall.queryHistory(QueryHistoryTall.java:886)
at com.bouyguesenergiesservices.ignition.gateway.replay.tag.QueryHistoryTall.lambda$queryHistoryAsync$0(QueryHistoryTall.java:170)
at java.base/java.util.concurrent.CompletableFuture$AsyncSupply.run(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$AsyncSupply.exec(Unknown Source)
at java.base/java.util.concurrent.ForkJoinTask.doExec(Unknown Source)
at java.base/java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(Unknown Source)
at java.base/java.util.concurrent.ForkJoinPool.scan(Unknown Source)
at java.base/java.util.concurrent.ForkJoinPool.runWorker(Unknown Source)
I think this is a bug on our side. Not sure there’s anything you can do to fix it. I’ll make a ticket…
thanks, I stay tuned.
Did you find anything ?
The ticket has been designated to be picked up “next sprint”. I don’t have any more details about it.
This is fixed in 8.1.2.
what if you can’t switch from 8.1.0?
any insight on how to make it either happen less often, or avoid it?
I have a report using a historian query, and just that page is giving me the error of comparison method violates its general contract.
@paul-griffith
broke on Sunday, had been working
Then you can't get fixes. Upgrades contain bug fixes. No upgrade, no bug fix.
Sometimes there are work-arounds, sometimes not. As noted above, this is one of the unfortunate "nots".
I am going to avoid the simple table in reports for now, as it seems like the only thing that broke. (8.1.0)
I don’t know if it uses the history manager in a similar manner.
Other pages were not impacted. None of my pages use the getTagHistoryManager() function afaik.
I think a reset of my gateway would temporarily fix the issue, but I don’t have the ability to do that yet.
Just for my silly curiosity :slight_smile: , but why can't you?
I am too far down the totem pole of my company.
Also, they had paid someone to make a bunch stuff in Ignition, and they don’t want to pay them to fix that stuff if it breaks upgrading probably.
