I need to create simple template Just to drag the tag and showing tag Name +Tag value .
any idea on that
There is free training available at
https://www.inductiveuniversity.com/
I believe you would find an example in the Ignition Basics module of the type of thing you are trying to do.
Late reply… But, you can’t do this with a simple tag. You can do it with a UDT (although I wouldn’t recommend using UDT type custom properties)
You can however drag a tag on and auto create a number of components, including a numeric label, that auto bind to the tag, you won’t get both the tag name and value though together
