tagPath URL parameter - best practices?
We use tagPath for everything and I'd like to figure out a clean way to pass a tagPath parameter to a page URL such as /node/:tagPath. However per the docs and common sense, / is a disallowed character in a URL parameter. Any simple ways people have substituted or worked around this?
For now, all our nav is done to views rather than URLs, but I like the representational state aspect of a URL whenever possible.
It would have to be URLencoded.
I mean it's simple to take in a tagPathEscaped parameter via URL, then do a simple replace({view.params.tagPathEscaped},"~","/") expression to convert to a valid tagPath.
But I can hear you saying "bleghh" to that and I was hoping for a more glamorous solution to escaped urls such as
data/perspective/client/project/node/Path~to~tag~right~here
Yeah, Ignition allows a lot of characters in tag names that aren't legal in URLs. If you use the standardized encode/decode tools, you won't miss anything that will need fixing later. Hmmm?
Not so simple. :man_shrugging:
And of course there's already an expression that takes care of that. There's always some new expression to find. urlEncode | Ignition User Manual
urlEncode('Path/to/tag/right/here'), used to create a URL nav such as data/perspective/client/project/node/Path%2Fto%2Ftag%2Fright%2Fhere
loads right into view.params.tagPath decoded and ready to use.
Not pretty, but representational and back button/bookmark friendly. Now I feel like an amateur for asking this in the first place. There's always expression functions in the banana stand.
