Hello All,
I am facing some bugs while configuring OPC tags. Trying to collect data from Siemens WinCC RT advanced SCADA to Ignition through OPC UA.
Siemens WinCC will act as OPC UA server and ignition as Client.
Here the problem came i can able to access all the tags by using UA expert OPC client software. While in ignition, OPC connection status “Connected” and the folders are visible but the tags under the folder was not visible.
version info:
Wincc RT advanced - Version V 14.
Ignition - V 8.1.5.
Also tested with Ignition V 8.1.19.
