Making edits in the datatype takes a long time to save and 50% of the time throws an error.
I have tried it on a VM with 16gb RAM and a dev environment on my offices server with the same RAM.
Not sure if the environment is not powerful enough or if my structure is too embedded.
The long save times can be a minute or so, or a few minutes, then it errors.
It just says error writing to tags, and I can not see the detail section. It will not let me click it, or exit, then it is stuck until I end the Zulu process.
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Results for asynchronous rpc call were not received within the specified amount of time [60000 ms] for task ‘9563328d-b4a2-483f-a5de-b97d8ae2bb0e’
Detailed:
java.util.concurrent.ExecutionException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Results for asynchronous rpc call were not received within the specified amount of time [60000 ms] for task ‘9563328d-b4a2-483f-a5de-b97d8ae2bb0e’
at java.base/java.util.concurrent.CompletableFuture.reportGet(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.get(Unknown Source)
at com.inductiveautomation.ignition.designer.tags.frame.actions.TagImportTask.sendToGateway(ImportExportActions.kt:200)
at com.inductiveautomation.ignition.designer.tags.frame.actions.TagImportTask.run(ImportExportActions.kt:150)
at com.inductiveautomation.ignition.client.util.gui.progress.ClientProgressManager$ClientRunningTask.run(ClientProgressManager.java:511)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:544)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Results for asynchronous rpc call were not received within the specified amount of time [60000 ms] for task ‘9563328d-b4a2-483f-a5de-b97d8ae2bb0e’
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:321)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:954)
at com.inductiveautomation.ignition.client.tags.impl.GatewayTagInterface$GatewayProviderProxy.importTagsAsync(GatewayTagInterface.java:577)
at com.inductiveautomation.ignition.client.tags.impl.ClientTagManagerImpl.importTagsAsync(ClientTagManagerImpl.java:416)
at com.inductiveautomation.ignition.designer.tags.frame.actions.TagImportTask.sendToGateway(ImportExportActions.kt:199)
… 9 more
Caused by: java.util.concurrent.TimeoutException: Results for asynchronous rpc call were not received within the specified amount of time [60000 ms] for task ‘9563328d-b4a2-483f-a5de-b97d8ae2bb0e’
at com.inductiveautomation.ignition.client.util.gui.progress.ClientProgressManager$RunningTask.waitForResult(ClientProgressManager.java:453)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:305)
… 14 more
Ignition v8.1.20 (b2022082313)
Java: Azul Systems, Inc. 11.0.15
This only helps if you actually configure Ignition to use more RAM. Look in your ignition.conf file for the settings. (And/or show a screenshot of your gateway's Status=>Performance page.)
