Tags disappearing on restart
So my tags disappeared twice today.
I have a bunch of tags within the default tag provider. When my memory utilization hits 90% and everything stalls, the gateway has to restart that's when I notice my tags disappearing. After I restart the gateway, and I relaunch the designer I see all my tags in the default provider gone.
I do have audit logs but it does not tell me anything and the gateway logs does not tell me anything either.
Does anyone know the cause or how I can find the root cause? I don't want to keep reloading backups.
Have you checked your hdd space? I've certainly seen strange bevahiour, saves to views and the entire views just vanishing and the cause was 0 MB free on the gateway.... Very nice
Yes, I have a lot of space left.
I'd interface directly with support on this one. This seems like something they would want to dig into.
Hello. Did you figure out anything here?
We are experiencing similar issues where after a restart old tags reappear and the newly created tags disappear.
Seems like the new config is only held in memory and after a reboot a persisted config is restored.
We use the APIs to write in all tags.
Their post was from a while ago around a time there were some bugs that may have been responsible for this. I've seen a similar problem on redundant systems and I know that problem has been fixed for a while.
If you're having this problem and not on a fairly new version you may want to consider upgrading to a newer version to get any bug fixes.
You can also always contact support to get some help on it.
Hi guys, just wondering if anyone found any cause to this, we are also experiencing similar issues, we create a bunch of tags via a script, then after restart they are gone and old tags are back. This seems to be fixed if we export and reimport the tags via the designer, but is less than ideal. We are currently using 8.3.3.
Would be good to get some understanding if there is a difference between a tag import and using system.tag.configure, we also use system.tag.deleteTags to clear all tags out the folder before creating new tags.
Does your system have a redundant failover? I'm asking to get a data point associated with it in case it's helpful.
Do you call them back-to-back? IIRC, those calls have some asynchronous behavior--you may need to dwell a few seconds after deletions before creating the replacement batch.
No Redundancy, and yes I do believe there is no delay between them, it deletes everything in the folder and goes straight to configuring new tags. Never gave it much thought as the result was always as expected, as in the folder got cleaned and all expected new tags were there. I will do some testing on this and see if a delay helps, if this is the case it would be good to get a mention of it in the docs.
Do you know which specific version this was fixed in? I'm experiencing this exact problem on a redundant pair of gateways on 8.3.6
I don't know. I think we had the problem in 8.1.44 but that's off the top of my head so it may have been a version around 8.1.44.
Edit: To be clear. I'm suspecting you have a similar problem to the one we were having. I believe the problem we were having was fixed a while ago.
Ok, I'm seeing this happen on 8.3.6, so obviously way later. I did see something mentioning tag sync issues in the 8.3.9 patch notes that just came out, but that could be unrelated.
Specifically my observation aligns with this issue in that it only happens on a gateway restart, and we are using a redundant gateway topology. Tags seem to "roll back" a few weeks every time we restart the primary gateway.
