Tags Ignore Audit Log
Is there a way to have a tag ignore the audit log? I have some UDTs with memory tags, these tag values are changed via scripting. Whenever the tag values change the audit profile will see it and insert in SQL. I would like the audit profile to ignore a group of tags. I didn’t see a way, curious if one exists.
Nope. You could run some periodic task that drops records from the audit log matching a filter, but there’s no granular control over what’s audited.
@paul-griffith still no update regarding the possibility of avoid log certain tags? We have an handshake with the PLC that we don't want to log
Not at the moment. There's a feature planned for 8.3 that might cover this use case indirectly, but generally speaking folks want auditing either on or off, so there isn't a lot of demand for more granularity.
As you describe previousluy at this time the only solution is to run a scheduled script that "clean" all che unwanted insert SQL side!
If all you are doing is showing data in a table, you could also ignore the results by adding a where clause, using the specific tag in the action_target.
There is some metods to get the audit name of the current project on witch is running the audit?
There is someting similar for get the database connection info
connectionInfo = system.db.getConnectionInfo()
name = connectionInfo.getValueAt(0, "Name")
There is a possibility to get the table name from audit gateway configuration?
@paul-griffith, any chance this ‘indirect feature’ got implemented in 8.3? If so, are you able to elaborate? It seems to be a constant (quarterly) headache of mine, to work through items that are causing unwanted (millions of) rows in the audit logs. It would be very beneficial to be able configure auditing with more granularity - either at the tag-level or at a system-wide configuration level.
No. My previous post was vaguely alluding to the 'event streams' feature, which at the time I was posting hadn't fully crystallized. The thinking was that it was going to be a very generic event -> filter -> map -> sink pipeline, so in theory we could have system generated audit events as a 'source', and put you in charge of whether they get sent to (any) destination handler(s).
But as far as I know we don't have any actual plans to do so, at the moment, though a revisit of auditing in Ignition in general is in the cards.
