Hello, after an hour searching for post with this aclaration…
this is de question, i remember checking at 7.9 version a window in the gateway witll all the scanclasses ordered by execution/sec and all the tags subscribed to that, in 8.1 the only thing ive found is the executions so far of every tag group in any provider, is there anything similiar to what i am searching?
To check the subscription statistics per device, you can use the Device Details status page as detailed here: Connections - Devices - Ignition User Manual 8.1 - Ignition Documentation
To check the subscription statistics per OPC Server, you can use the Client Diagnostics page as detailed here under Clients: Connections - OPC Connections - Ignition User Manual 8.1 - Ignition Documentation
Are either of these what you are looking for in 8.1?
its pretty much what i was looking for, thank you a lot
