Tags to read from PLCA or PLCB (topic change as old InTouch)
I’m trying to replicate old InTouch behaviour using topic change for tags depending on which PLC is connected.
I have two PLCs PLC_A and PLC_B. I wrote script with rolling counters between SCADA - PLCs which identify which PLC is a master and write other PLC_A or PLC_B to string tag called Topic.
Tags are exactly the same in both PLCs so I was thinking about creating generic tags in Ignition which can read from PLC_A or B thanks to changed topic. Is it possible to not address tags directly but to use my tag “topic” in a path so the tag will address to correct PLC?
Thanks in advance.
Is this an Ethernet device?
You could change the physical host name in the configuration through a scripting call:
system.device.setDeviceHostname | Ignition User Manual
I’ve used this to switch between an Emulator and a physical PLC that have identical tags.
