I setup a TCP connection to a remote device in ignition. The remote device as a TCP server that is supposed to respond with information whenever a connection is requested.
Using QuickClient I can subscribe to the remote device and see that it works when a message is sent. Again, the TCP Server should respond just when connected, whether a message is sent or not.
But I have the QuickClient setup to poll every 1000 ms and it does not appear to be polling. When I look at the same tag in Ignition designer (where I think it should recognize new values coming in every 1000ms) it also shows only a static value.
The scan class for the tag is set to rescan every 1000 ms as well.
What am I doing wrong?
