Hello,
I am having trouble with the TCP Driver. I notice this issue arises after the TCP Server I am running has been inactive for a while. When I close the TCP Server the Status tab says 0/1 Connected but the OPC Diagnotics tag “Is Connected” is still true. This is a problem because I use the “Is Connected” tag to update the PLC on the TCP status.
I will try to attache images.
Running Server 7.9.7 on Linux
