Teltonika SMS Notification Module
Hey Ignition Community!
We're excited to announce the release of our Teltonika SMS Driver for Ignition by BRE Services - a robust solution for SMS communications in your SCADA systems.
What's New?
This driver enables seamless SMS functionality through Teltonika industrial routers, providing reliable and secure alarm notification capabilities for your Ignition applications.
This driver escapes the drawbacks or other SMS platforms by using industry standard mechanisms and security for both runtime and configuration.
Key Features:
  • Ignition 8.1 Integration - Works directly within your Ignition gateway alarm pipelines like any other notification profile.
  • Easy Setup - Be up and running in no time with very simple configuration.
  • Teltonika Hardware Support - Compatible with Teltonika RUT-956 series routers (Also probably a few more but we haven't bought them all to test with yet)
  • Reliable SMS Delivery - TCP/IP communication with TLS encryption ensures message delivery packets are not lost or intercepted.
  • Industrial Grade - Built for 24/7 industrial environments
  • Secure - The Teltonika hardware can be effectively isolated from the plant network using normal IT firewall tools, the connection is routable, secure and easy.
Get it here:
BRE Services - Teltonika SMS Driver for Ignition.
We have now been listed on the Module Showcase:
Hey Dave, does your module support 2-way reply SMS? Have you use the RUT956 for hosting a VPN server before?
We're on the lookout for a solution for small customers that gives them both 2-way SMS and VPN access
Hi Nick,
Yes the module has 2 way SMS for alarm acknowledgment. I have also used the RUT series for VPNs a fair few times. Very cost effective, but don't expect full wire speed from such a multi-use system.
