Template appears grayed out on Vision
I have a template that, no matter how I put it in a window (dragging & droping, template canvas etc), appears grayed out.
This is a part of the template on the Designer:
good
and this the same part in Vision:
bad
Throughout the page, I noticed that only components with a Background color property are being grayed out, all other components display properly.
The template is the only component in the window.
In the template editor [not the window editor] are the enabled properties unchecked?
...or is there a binding of some kind on the enabled properties?
If by template editor you mean this, here it is:
Also, there are no bindings anywhere on the page.
I tried creating another template to check if the same thing happened
e
and I dragged it on the page and it appeared normally
but on vision there is still the same issue
It's just this template, and I can't figure out why.
On a side note, we both have a cup of coffee as our profile picture :grinning:
You need to edit that template, and look at the individual components within that template. Look for anything that would affect the enabled property of the greyed out parts of the template.
Unchecking this property in the subcomponents of the template is what causes the greyed out appearence:
Something is unchecking the enabled properties of the internal components within the template.
