Using v7.9.6, I am noticing an anomaly in graphic behavior of templates at the edge of the template.
If I have a template that has a line along one edge that is anchored top, bottom and left and then stack a several of these templates together, I get a seamless line along the left of the stack as expected. If, however, I embed this template in another template and I anchor the embedded template as well and then stack several instances of the nested template, I get a 1 pixel gap in my line even though both templates are set to border = none, both templates are the same height, the line in the embedded template is the same height as both templates. Is there a workaround to this or can I just not have my border line nested inside an embedded template?
Thanks for any input.
